You wouldn't even have to order them to do that. Just buy a few feet of 1.75“ 1/8" wall 4130 tubing from your local metal place and have your local machine shop part it off in a lathe at the sizes you want. It's a 1 operation part, shouldn't cost more than 5 bucks a part if you make 20 or so. Most shops have a minimum charge for setup, so you'll spend at least 100 bucks, or maybe a 6 pack if the guys can do "government jobs" on the side.
I just sent for a front wheel bearing "Spacer Selection Tool"
Last edited by Advancedynamix; 12-14-2016, 06:55 PM.Driving for me is neither a right nor a privilege. Driving is my passion, as it was for the people who invented the automobile, the people who paved the first roads and the people who continue to improve the automobile. Please respect this passion.
I ordered just over 50 of them and the total was less than $100.00 including shipping.
IanIan
From FourGreen?Originally posted by fastivaca View PostI ordered just over 50 of them and the total was less than $100.00 including shipping.
IanDriving for me is neither a right nor a privilege. Driving is my passion, as it was for the people who invented the automobile, the people who paved the first roads and the people who continue to improve the automobile. Please respect this passion.
YepOriginally posted by Advancedynamix View PostFrom FourGreen?Ian
Arent they hardened?Originally posted by Advancedynamix View PostYou wouldn't even have to order them to do that. Just buy a few feet of 1.75“ 1/8" wall 4130 tubing from your local metal place and have your local machine shop part it off in a lathe at the sizes you want. It's a 1 operation part, shouldn't cost more than 5 bucks a part if you make 20 or so. Most shops have a minimum charge for setup, so you'll spend at least 100 bucks, or maybe a 6 pack if the guys can do "government jobs" on the side.~Nate
Current cars:
FOTY 2008 winner!
4130 chromoly is pretty strong stuff and being it's just gonna be pressed by the bearings I don't think it's need to be hardenedOriginally posted by skeeters_keeper View PostArent they hardened?
Sent from my iPhone using TapatalkFestiver
93 L find/5 speed
BP/g15mr swapped
Aspire brake swapped
stripped and sold due to rust
89 festie
rustful
93 festie
advanced suspension
kai/skeeter camber
b3t/g15mr
No, they seem to be made of DOM as is. I use 4130 as a precaution (and I already had the tubing, lol)Originally posted by skeeters_keeper View PostArent they hardened?
With the right set up (bar fed, high speed etc. ect.) These could be made for 50 cents a spacer including profit. I don't see much volume in it though.
BTW, the size I see most commonly used by the factory is 12 or around a 12. I just pulled 4 sets of knuckles apart and they all had 12 shims in them and they were from 3 different kinds of cars (Capri xr2, Aspire, Festiva).
They are all within .0005“ too, which is cool since they came from different cars, different years and different brands. They are all from the same source, I'd put money on it.Last edited by Advancedynamix; 12-15-2016, 11:08 AM.Driving for me is neither a right nor a privilege. Driving is my passion, as it was for the people who invented the automobile, the people who paved the first roads and the people who continue to improve the automobile. Please respect this passion.
^ This,all of this... Found the tube on the spare metal rack, surface ground them to various sizes etc. And I also have a bunch of number 12's.
I like to to set mine up on the higher end of the torque range. IDK if its my torque wrench,but when I set them up on the low side. I was only getting 10K from the bearings.
Just so people on the forum know, I have been discussing doing a bunch of these and selling them for a hopefully reasonable price, but the discussion has been on Facebook. I have 8 cores now and hope to have at least four more before I start rebuilding.Contact me for information about Festiva Madness!
You are making the same mistake I did when I read it. The bolt you have will work. Pics coming in a minuteOriginally posted by Greywolf View PostMy "BUG" right now is that the tool came with a bolt that will not fit all the way through the wheel bearings and hub.
I'm guessing that the size and thread of the bolt should be very close to if not exactly the same as the nut and bolt on the end of the drive axle, and I am saying that because the axle nut torque is stated as 116-174 lbs/ft for both Festiva AND Capri (NOTE: THE SAME TOOL is used for both, I have verified it)
Originally posted by Greywolf View PostWhich Rio?
I think I've about figured out a jig I can make to drive out my hubs that will be supported by a pair of jack stands.
It will use a chunk of 4x4 with eye bolts or something to suspend a knuckle beneath it, with a hole bored in it to drive a wooden dowel or some kind of punch through.
I'm still thinking over the simplest and best way to do it without mangling anything or having to pend more money than the average Joe would want to.
Done right - I plan to come up with something simple, easy, and that you could build out of scrap even if you broke down in La Paz or somewhereContact me for information about Festiva Madness!
This one I'm rebuilding is turning at about seven inch pounds smoothly. I see now why Charlie has to replace them all the time and I don't blame him a bit for shooting at five inch pounds. If I'm racing I'll do the same, but for a daily driver, I'm gonna say this is in spec and let it roll.
Sent from my C6730 using TapatalkContact me for information about Festiva Madness!
