I just sent for a front wheel bearing "Spacer Selection Tool"
  • #61
    Originally posted by Greywolf View Post
    Which Rio?
    * If Ford has them, I bet they FORD PRICED them too...
    I think I've about figured out a jig I can make to drive out my hubs that will be supported by a pair of jack stands.
    It will use a chunk of 4x4 with eye bolts or something to suspend a knuckle beneath it, with a hole bored in it to drive a wooden dowel or some kind of punch through.
    I'm still thinking over the simplest and best way to do it without mangling anything or having to pend more money than the average Joe would want to.
    Done right - I plan to come up with something simple, easy, and that you could build out of scrap even if you broke down in La Paz or somewhere
    [QUOTE=scitzz;731965]
    Not only can you knock it apart like I did in that video, but the rotunda tool you bought should have come with a knuckle separator as well. Instructions on how to use it on the inside lid.
    • #62
      It is possible to get them apart using the press. I suspended the knuckle from the top using HEAVY tow chain and high grade bolts through the strut hole and tie rod hole. I put an impact socket under the top of one of the chains looped over the top to get it close to level and 2-3 short pumps on the bottle jack pops it loose. Must easier on my antique arms than the pounding method, which I have done, too.
      "Blue92"- 92L 5 spd, original owner- 185K, B8,DD..
      "Pedro"-88L 5-spd, B6D (built by Advancedynamix)
      "Blanca"-92 GL auto, 125K(FM8 Lowest Miles)- B6 daughter's DD
      "Tractor Blue"- 89 L auto, 110K
      "Chester"-88 LX, runs but not street legal
      "Wenona"-89L parts car
      "Flame"- 89 LX 5 spd ,parts car
      • #63
        Originally posted by scitzz View Post
        Now I'm confused... units change from inch pounds to foot pounds but the N.m numbers don't change. I'm assuming this is a typo!
        Ian
        • #64
          I made a press. It spins the bearings while it presses the hub out. This preserves the bearings, so they can be reused if necessary (we don't always have new bearings at the race track).
          • #65
            Seeing Charlie's picture reminded me that I'd mistakenly said "strut hole"
            but it was thru the pinch bolt hole. Sorry, if this confuses, but it was too late to edit.
            • #66
              Looks so much like the rotunda tool.
