OK I got my latest festiva a few weeks ago. I traded one of my festivas (230,000 miles needs head gasket) to a festiva buddy for the parts and labor to fix it. It is a carbed 88 LX. It had sufferd a carb fire. After some repairs it idles fine, and sounds perfect. When you shift into second it acts like it's starving for fuel. After it starts that mess it continues bucking no matter what gear I'm in. My buddy (oneeyepizzaguy here)
1. replaced all the vacuum lines
2. put in a new fuel filter
3. replaced the fuel pump
4. I checked the pickup filter and looked for trash in the tank (clear)
5. replaced the firewall mounted stuff??? solenoids?
6. replaced the carb
7 replaced the air cleaner housing with that whatever you call it thing on the side of it.
8 replaced the air filter
9. sprayed alcohol around the carb and whole intake, vacuum area to look for a revving up indicated vacuum leak
Still it bucks and won't go. :evil:
Next is plugs, wires, distributor cap, and rotor button.
Any suggestions for fixing the bucking mess? :help:
thanks
thanks
