OK so i've but about 200mi on this engine now, and have been having this problem since the begining. Here's a vid of the most noticable problem:
The other symptoms are:
-high idle (can't tell how high i don't have a tach)
-the engine keeps revving for a few seconds after i clutch-in between gears and then it dies down
-I also keep getting a code-17, O2 sensor code, but not the o2 sensor fail code its more an of emisions thing, most likely due to improper fuel/spark (according to Haynes).
-Also seems to be drinking gass...
It seems to me that my timing is about 50* TDC, but as you can see its not running very bad? and if i retard the timing it begins to stumble.
BUT i'm very confused about the timing. In this pic i have the crank/cam marks ligned up as TDC, and the disty rotor is pointing at the #1 plug terminal, see where the timing mark is?
I used the B3 pulley (in better condition) but the marks are at the same place on the B3/B6 pulleys. I've also got the B3 distributer installed. New plugs/cap/rotor (wires are good). no vac leaks that i can find. I cleaned the injectors by hand when i had them out (9v batt to keep them open and carb cleaner).
i'm going to try changing the TPS, or mabye i've got a disty problem, but the disty was running my dying B3 OK....
any ideas are much appreciated!
after playing with the timing a little more this everning though (i had it too far retarded earlier) it is much pepier, about what i was expecting out of the B6, but it still sputters a little at (high) idle, and keeps reving after i clutch in, though perhaps not as badly...
