Well i hope you found it! i know one of the first things i did was make sure my grounds were VERY clean and tight, i even added an extra jumper from the manifold to a ground during testing to check.
as i recall, someone else found that a ground was the cause of a similar problem... i figured that would have been one of the first things you checked!
Well, i hope thats your problem because that would be a very easy fix
perhaps that is other folks problems as well.
i just sealed (or attempted to seal!) my exhaust leaks this AM, since it was leaking just past the headder i'm thinking perhaps that was causing my 02 sensor to see something funy? not sure but i'll find out soon i suppose!
perhaps that is other folks problems as well.i just sealed (or attempted to seal!) my exhaust leaks this AM, since it was leaking just past the headder i'm thinking perhaps that was causing my 02 sensor to see something funy? not sure but i'll find out soon i suppose!
