Well my problem is slightly different, because under load the engine seems to run fine (not stubmling on acceleration, and not loosing power exept when i retarded the timing too much.)
Right now the problems with my car are: high idle, slight "stutter" (missing) at idle, WEIRD ignition timing, and 22mpg!!!!!!!!!!!!
after a bunch more troubleshooting last night here's what i have come accross.
Conserning the idle speed issue: i have the idle adjustment screw (the one that holds the throtle cable/spring assembly out) all the way turned out, not tuching the stop at all. the idle is still high. I messed with the screw under the little rubber cap (controls the amout of air alowed to bypass the throttle plate at idle) some and it didn't seem to affect the idle at all....
I also attempted to check the ignition timing again, its showing about 20* BTDC at the high idle with the mark i made, i'm assuming the aprox correct b/c of the high idle. BUT, every now and then the timing mark "jumps" to about 30* AFTER TDC, indicating that the plug isn't sparking till way after TDC, which i'm assuming for now is the cause of the slight missfire at idle, i'll look into that more tonight.
this leads me to think that it is ignition related rather than fuel related, although i may still have a fuel problem because i doubt this ignition problom would cause me to use 9gal of gass over 200mi (since a lot of this gass was used sitting idling trying to trouble shoot the thing maybe i actually got more like 30mpg while driving, but thats still unacceptably low).
the last test i performed yesterday was another Vac test. i'm reading a steady 24, which is a little high, but its idling fast. when i rev it up the vac drops and then jumps right back up to 24...
'comon guys, like kzbill said, keep posting everything you have tried or can think of we WILL solve this problem!!!!
but my code still keeps flashing, and my timing is wack. but it drives like a real car! :p
but it would make sense that if the metering vane was glitching out, it would not be mixing the fuel right and probibly dumped a ton of gas into the motor, explaining the black plugs and the gassy oil
