sounds like a likely cause to me! i assume you've checked your PCV system? if theres really enough pressure to blow by the seal then i would suspect your PCV valve or something isn't working correctly.
If this does turn out to cure the problem we will need to make a sticky out of it (perhaps in a more concise thread though). Props to you for spending so much time on trying to find the problem!!
