Junkyard Tranny.... now what?
    Originally posted by jglutz
    ^^That's not a bad idea....It's you car....maybe thou, before you dump in the good stuff...you might want to put a few miles on with some cheap stuff or even transmission flush just to clean it out.
    Yep already picked a gallon of regular cheapo ATF up. Does the festiva have a drain plug for the MT fluid? While im on the subject of that question where do you fill on this thing and how do you know its full?
      5 Speed....drain plug bottom right below the driver side output...Fill thru the Speedo cable port, right above the passenger side output...capacity, 2.6 qts.
      Joe Lutz
      The SKATE ..... 1992L 5spd
        Also, you can check the level, which should be done periodically, by pulling the speedo cable from the trans. I know you should check it, that is how I lost the only trans to go in my car, it got a leak when I parked in dirt, and never noticed till it was too late....
        Now I check that bugger like once a month
          2.6qts? is that right? The computer at work tells me 5.2 but that wouldn't be the first time it was wrong.
            ^Did you notice how small that trans is ? 2.6 is all you need.
            99 Dodge Caravan SE
            95 Taurus SHO auto 265hp
            94 F150 351W auto (for sale)
            95 Honda 1500 Goldwing SE
            95 Iszuzu Trooper LS
              that 5.2 may be for the re-fill for an automatic trans after a fluid and filter change. i have never changed the fluid in an auto trans. so i don't know for sure.
              1960 willys pickup
              1967 jeep cj5
              1988 festiva
              1989 festiva
              1990 festiva for parts
              1991 s-10
              "Democracy is two wolves and a lamb voting on what to have for lunch. Liberty is a well-armed lamb contesting the vote!" —Benjamin Franklin, 1759
                5.2 pints = 2.6 quarts
                Jim DeAngelis
                kittens give Morbo gas!!
                  ^^There's a thinking man!
                  Joe Lutz
                  • #24
                    i've got a bad habit of only thinking in quarts,i forget there are smaller measurements also. C.R.S. is coming with my old age!!!!!
                    1960 willys pickup
                    1967 jeep cj5
                    1988 festiva
                    1989 festiva
                    1991 s-10
                    • #25
                      Wow... they should label it in our work computer... wonder how many times I gave out the wrong amount ....
                      • #26
                        I have heard that it is better for your engine/transmission, to stick with the kind of oil as its used before, and using the same king can provide more benefits than switching to a 'better' oil. just something i heard.
                        Proud owner of 92L, 350KM, Home made muffler, sounds like a truck! 16 years without replacement of anything but filters! 5spd EFI, Anyone else's shifter look like its from a quarter-ton?
                        • #27
                          I think that info is more related to automatic transmissions then manual transmissions. But this is just my gut feeling and opinion, fordfest78 is not responsible for any damage done to your trans for putting in ultra super shift omg pwnzer fluid 5000 in your vehicle.
