Not sure if this should be a sticky or not but after reviewing the Haynes manual, and others, there is nothing very clear about how to retrieve the trouble codes from the On Board Diagnostic I (OBD I) system on 1985 to 1995 Fords.
So with that said when your check engine light comes on open the hood. In the engine bay, drivers side, next to the fire wall you will find a 1 pin female connector. This is the STI terminal. Take a jumper wire, ground one end to bare metal in the engine bay and the other end should go into the 1 pin STI terminal. Turn the key on without starting the engine. Watch the check engine light as it will flash the trouble code. Long flashes will be the first number of the code, short flashes will be the second number. Short flashes only will be single digit trouble codes (example, 9 quick flashes will be code 09 which is the Coolant Temperature Sensor). This is for OBD I systems only.
Hope this helps but if not ask questions!!!!
