Ive said it before and Ill say it again because this comes up fairly often. The 91 - 96 Escort relay WILL work. Theres just a little tab that you have to break off the relay in order for it to fit properly.
Ha you just reminded me of a other post - I answered my own question when I got my manual back
Yes only one headlight relay for both lol
Good to know, so when I'm in the JY where is the headlight relay located on the 91-96 Escort?
^^^ Dude you make too much money or I'm just a cheap ba ..... bakers son, yeah, bakers son that right!
they arnt that much I priced one out the other day
Cheaper than $2 at a JY?
I agree, when you need one now just hitup the Mcparts stores.
But, if I'm in a JY I need to collect these, just like the fuse cartridges, which I have sent out and given away more than a few sets.
Reason: SP
Yup... It'll be on my list of things I grab when I see, just incase.
I assume you've found the relay?
I just fixed the headlights on one of mine. Same exact symptoms as you. You could hear the relay click, no high beam indicator on the cluster. The problem was corrsion inside a white(?) hardshell connector on the headlight wire. I THINK that wire was red/white tracer. It's located real close the the headlight relay. I tried cleaning the pins, that didn't work so I just jumped around the plug.
Sometime during the swap of headlights and the install of my tach cluster, I've lost my headlights...
Funny you should mention this. On my trip home, I lost headlights while going down the highwway. I just barely touched the switch, rotating it forward, and they came back. No further problems. Interesting.
You can avoid reality, but you can't avoid the consequences of avoiding reality--Ayn Rand Disaster preparedness
Looks like I'll end up buying the Escort relay, since none of the stores seem to have anything that'll "fit" the Festiva.
What tab are you talking about? Or.... When I see the thing, will I realize what it is?
Any chance of a pic showing the two side by side.
Not necessary, but helps a lot.
