So..... this is what we found out today
NO SPARK
NO FUEL
fuel pump relay is good
Ignition switch is good
Coil is good
swapped out VAF no luck
no obvious broken wires
there where 3 grounds in tact, one under the distributor, one on the VAF, one on the trans
let me ask when you guys turn you key foward does the CEL come on for a second? his wont, we tried groundint out the sti wire to retrieve codes but not a blink! there where 2 wires and we werent sure which one was the sti, one was black the other is white. sooo this gremlin is realy hiding!
we did not check the fuel pump, but thinking that is not the issue since there is still no spark. the ecu is a grey area, he swapped out the orginal for a ebay one so its a mystery if it could be the ecu.
NO SPARK
NO FUEL
Coil is good
