Don't give up yet! Try the ignitor. Its about 1" square and sits beside the coil on '90-'93. On '88-'89 it's inside the distributor. They go bad suddenly sometimes. This causes no spark to the distributor. Sound like what you have going on. Also sounds like you have eliminated alot of other possible causes. Problem is ingintors are between $75 -$120 new. I have about 4 or 5 good used ones. I've tested them on a car by swapping them out and running them. Easy 2 minute swap.
The early style in the distributor is a bit more involved swap. Usually cheaper to get a complete rebuilt distributor for $150 as the ingitor alone can run as high as $185
