So when i got my 88 festiva a couple months back (Traded my snowboard for it) The guy said it needed a valve cover gasket and that it burnt some oil at the same time. I did the valve cover gasket the next day, and now it doesnt leak any oil. However, it burns a TON of oil. I am definitely thinking it is the piston rings but i was wondering if it could be something else possibly? Help me out guys
Burning alot of oil...
You know I little info on how much it smokes, when it smokes, does it smoke all the time, might help us help you.
How much is a "ton of oil"?
A quart in 100 miles, 500 miles, 1,500 miles?
What do the spark plugs look like?
Most likely rings.
As perucho said, a leak down test will tell you what you need to know.'93 Blue 5spd 230K(down for clutch and overall maintanence)
Its either rings or valves seals. possibly head gasket.89L build thread http://www.fordfestiva.com/forums/sh...ad.php?t=36422
My site: 20tessa.sytes.net
Originally posted by Pu241 View PostYou know I little info on how much it smokes, when it smokes, does it smoke all the time, might help us help you.
Most likely rings.
88 Festy L (The White Thunder)
91 L came and gone, owned only 2 days
Is there oil in the coolant?'93 Blue 5spd 230K(down for clutch and overall maintanence)
if you're going that far, you should replace the valve guide seals as well.Trees aren't kind to me...
