What exactly is a hub? what does it look like?
Front Bearings Going - I have Questions!
its the thing that holds the wheel bearing in place, also has the axle going thru it and its what the caliper mounts to...
Mike, AKA the sasquatch
easy... just got done putting 2 new-ish ones in to timmay89's car and i helped with his aspire swap on the white car of his and did the aspire swap on my own... not that hard, its only like 6 bolts per side... (10 if you count the wheel lol...)
ill pm you and we can make a time to do this
you should inspect your lower control arm bushings for cracking or chunks missing, pull the wheels and inspect your pads for wear and make sure the sliders move freely (compress the caliper piston with small pry bar and then check the sliders). with the wheel off, turn the hub by hand and feel for binding and roughness (hub should take a little effort to turn, but it should be SMOOTH).Trees aren't kind to me...
