Water Pump Failure
  • #31
    Every timing belt I've did I put the timing belt on the crankshaft pulley first. Then halfway on the tensioner and usually takes a screwdriver to force it on the camshaft pulley. It's tight and a pain but once you do it a couple times it's nothing.
    91 rusty Festiva 260k
    • #32
      DONE!!! All I had to do was loosen the tensioner a hair. Call me crazy, but I feel like it is running BETTER than before. We'll see how she does on teh route tonight.
      Buck.
      -1993 Ford Festiva GL, ~200k, B6, Aspire rear, Rio front, 5-speed. '87 Prelude alloys. Happy to be back on the route!!!
      -1999 Toyota Sienna XLE, 346,000
      -1996 Chevrolet K1500 Z71, 350 V8, 198k, hauler
      • #33
        OK, look forward to you reporting results.
        It is possible it is running better!
        Just make sure you got both static and dynamic timing set correctly.
        • #34
          Static and dynamic???
          And she did great!!!! She is REALLY needing some front pads, though. We'll see if I can even bust the wheel bolts off.
          Buck.
