This is probably the stupidest thing I have ever done.
In the process of using a small 4 oz. oil can to pump Seafoam into the cylinders of my Aspire through the spark plug holes, I attached a short piece of black heat shrink tubing to the end of the spout and used a green twist tie to secure it. The stupid part is that I had only a scant 1/8 inch at the tip of the spout to attach the tube and as soon as I inserted it into the first hole (cylinder 4 actually) I hit the side of the hole with the tube and the first pump saw the tube with twist tie attached shoot into the hole.
That's pretty well the bad news. The good news is that it didn't fall into the combustion chamber but stopped with the top of the tube, with twist tie still attached, about half way down the threads of the spark plug hole. Here is what it looks like.
I don't know why it didn't fall all the way. Maybe it hit the top of the piston. But I figure I shouldn't count on that and believe my wisest course of action should be to treat this as a one time only shot at grabbing it with some very long pliers or something of that sort.
I plan to ride my bike to Harbor Freight tomorrow to buy one or more of these pliers. I'll return the ones I don't use, but I figure my best decision would be made with the tools in hand as I survey the actual situation.
Here are the problems I envision. Using straight pliers would tend to block my view of the tube which is critical to this working the first time. On the other hand, because of the depth of the recess, I would doubt the pliers with 90 degree offset would reach deep enough into the recess to be able to grab the tube. Maybe the 45 degree would work, but I would probably have to put it into the recess to know for sure. I figure my best bet is to have pliers long enough that I can use both hands to hold them open just the right amount and to be able to close them with a high degree of control. I'm hoping I'll be able to steady the pliers on the top of the hole as I position one of the jaws into the tube opening and the other below it. Then carefully, but quickly, close the pliers in a death grip that will not be released until the tube is out.
I doubt anyone has had to face this particular problem, but it is so important that this work the first time, I wanted to ask for help from anyone who might understand how critical success in this is. I don't need to tell you all what a dramatic difference there would be between success in getting the tube out and having it fall into the combustion chamber.
All suggestions and comments are welcome. You can even call me stupid if it make you feel better. But after that please tell me what you would do in this situation.
All you have is a little mechanical issue, which you will no doubt deal with successfully.
