In the next couple of days I'll be doing one of my favorite tasks in service to my Festiva/Aspire, changing the spark plugs. To me it is the purest pleasure since they are critical to the proper running of the engine, they are easy to get to, don't require a lot of cleaning, and once well done don't have to be touched for another 30,000 miles.
It was during the changing of plugs in my Festiva that I discovered what I call my Zen mode. That's where I am so engrossed in what I'm doing that I become completely unaware of time. I go from one task to the next without ever asking what time it is and when I'm done I couldn't begin to tell you how long it took or what time it might be at the moment you asked.
I've worked out a procedure I like to follow, even though it changes from time to time. But rather than tell you what I do, I'd be more interested in having everybody who wants to, tell exactly what steps they go through to change plugs in their own Festiva/Aspire. Let's say this is to be done on a pleasant, mild, sunny day, when you have no other pressures on your time that might cause you to compromise your standards and skip any steps along the way. Of course, you are free to say or not say whatever you choose, but here are a couple of things that I, for one, would find of interest.
As I said these are some things that would interest me. But if there are things you do that aren't on this list, those things would probably interest me even more. I may ask some questions along the way and at the very end reveal what I do in my Zen mode.
- What plugs do you prefer? Are there any you choose to avoid?
- How careful are you in gapping the plugs? Can you recommend a special gapper you like above all others? Do you trust the gap as it comes from the box?
- Do you loosen the plugs before blowing with compressed air, as I've seen advised? For those without air, would spraying with Brake Kleen be sufficient?
- How do you clean the threads in the hole? Do you chase the threads with something? What do you use for that? What kind of round brush would you use for cleaning? Nylon, brass, or steel?
- Do you apply anything to the threads of the spark plugs before installing them? What? Anti-sieze compound?
- Do you torque the plugs down? What kind of wrench do you prefer and what torque value would you use? Or do you just go by feel?
- Would you take this time to remove the wires and clean them? And maybe look in the cap and clean that up?
- Do you bother applying dielectric grease to the boots? On the insulation? How much do you use?
