Rear mains tend to not leak when running because it is slinging oil in the case. After you turn it off it will start dripping out under the crack. Use a piece of cardboard on the ground.
strange grinding and oil leak
thats possible. this stuff is pretty black. and there is a small leak in the endcap of my tranny and its coming out clear red.Originally posted by Damkid View PostOnly way to truly know is by pulling it apart, but if its leaking from in between the tranny and engine, it's either the rear main seal or a hole in your tranny, but since you say it's not tranny fluid, my guess is rear main
But on a quick side note, when my diff pin put a hole in my bell housing, after the tranny fluid mixed with the clutch dust in the bell housing, it came out looking like old motor oil, so i initially thought my rear main seal went...... just my 2 cents
