Okay, I am not so much asking for help on this, as just passing this along for the sake of conversation. I have an '89 carbed Festy, that dies at stop signs. Not every time. It is pretty random. 4 out of 5 times or so, it will sit there and run. It won't idle perfect, but acceptable. At normal highway speeds, it runs good, with surprising power. It is just so random. But, it will start right back up, perfectly. Like, two rotations of the motor and it is back on. The only time it did not, I was heading down a long hill on the interstate. Hit the off ramp, which took me uphill. Came to a stop, and died. But this time, it didn't want to crank. And, it acted like the battery was weak. The only time I have had it on the interstate, and the only time it didn't want to crank back immediately.
So, here is what has been done so far. New plug wires and plugs. Old plugs read good. No signs of oil fouling, overheating, etc. Pulled carb apart and cleaned. Rerouted some vacuum lines. Now, although I need to make sure I have them right, there are no leaks that I can find. And I am on my second can of Seafoam in the tank.
Now, today, I will add a see through fuel filter, and add some rubber hose. to the line. To me, it looks like the one currently on the gas line, is borderline kinked. I am also going to have the coil checks at McAuto's. I have a multimeter, but I don't yet have my Haynes manual to instruct me on how to test it myself. I also intend to have the ignition module tested while I am there.
Hopefully this will help. I also plan on dropping the tank to clean it out, but this will be later. And I guess I should consider going in and cleaning all connections under the hood. But, there really isn't a lot of corrosion visible.
Well, based on my limited knowledge, and help from the searches I have done on this forum, this will be my plan of action. I will keep you informed on what benefits, if any this plan has on my Festy.
