Pros and cons of the Festiva feedback carb VS. the Weber carb.
Nothing wrong with the orig feedback carb, if it is running good, but they work of off the sensors that are on the car and if a sensor is bad, will affect the operation of the carb, causing issues with performance, mileage, etc.
The o2 sensor is a known culprit of issues with the feedback system.
You can get an original rebuilt carb, for about the same price as a Weber.
But.. the Weber will allow the removal of the spaghetti like maze of sensors and vacuum lines that will no longer be needed with the Weber. o2 sensor included.
The performance of a Weber will be much better than the feedback carb, and gas mileage about the same. There is the needed adaptor plates. Some here have modded the plates that come with the (Weber Samuri?) kits. Others. like myself, have made their own adaptors.
