No fuel/ power?
  • #31
    Nitro. I do have kids. Maybe that's part of my fustrations. Lol
    89 Festiva. carby. needs repairs!!
    First time owner
    89 L carb'd - white / still needs work
    Bought for mpg and only paid $250
    • #32
      Right On,all the more reason to keep a level head & a level float @ idle.
      • #33
        In its current condition could you review how the car runs ?
        Does it start easy cold ? and how about hot after say 5 min shut down?
        does it idle smooth or?
        does it drive okay in town?
        does it cruise at 60 okay?
        does it have power to pass another car?
        • #34
          ^Yes, I was curious myself.
          91 Festiva GL "Scrat"
          82 Honda Goldwing GL1100i
          85 BMW 535is "Brunhild"
          • #35
            Yes to all the questions.
            First time owner
            • #36
              It starts easy when cold, and hot.
              It does have a rough idle.
              Oil in air filter area
              Will get some pics as soon as weather clears up.
              First time owner
              • #37
                Too much fuel. Cylinder wash and then blow by, oil pushed into
                air filter. Other possibility, low compression on a cylinder, but
                not 0, something like about 100 PSI.
                Discussion.. your needle and seat are probably okay based on your
                response to questions. The mixture control solenoid could be bad.
                You should start soaking your O2 with penetrating oil to get it out.
                Your CEL light is not coming on? With the 24mpg you are getting it
                should be. Does it come on when you turn the key on?
                Free tool program at AZ or Oreilly's borrow a compression gauge
                and test your compression. Pull all spark plugs, hold throttle open
                and crank for 10 seconds. Read gauge. Hold coil wire between your
                legs while cranking to prevent damage to ignition module...joking
                please unplug small wires from coil, same reason report back!
                • #38
                  PM me if you need parts
                  Thanks for helping him Movin.I turn my brain off ever time I see one of these Carbs.I have no desire to learn about them either.
                  Jbuck, if you need any parts. ie mix control solenoid pm me.
                  • #39
                    Check engine light comes on when I start the car. But it doesn't come on when driving.
                    First time owner
                    • #40
                      Your gas mileage is still 24 ? get the denso O2 . The entire feedback system
                      is locked rich because the o2 is reporting lean but not enough to throw code 17
                      Hopefully with the new o2 the rest of the feedbacks will unlock from rich and work
                      normally. If you want there is a good at home test you can do to check the rest
                      of the Carb and feedback for function.
                      • #41
                        Smoke coming out of muffler.
                        Is this also sign of burning rich?
                        First time owner
                        • #42
                          Which O2 sensor do I need to get?
                          First time owner
                          • #43
                            ^ what color?
                            as stated before: DENSO only.
                            • #44
                              ^^what he,said.
                              Blue/gray smoke- burning oil
                              Black smoke- too rich
                              89 L, hopefully returning from the dead soon with a little more power... :twisted:
                              http://www.fordfestiva.com/forums/sh...77-my-89-build
                              • #45
                                Your air filter full of oil needs cleaned up before you go looking at exhaust smoke.
