plus the carburetor has been like this for 7 tank of gas or more
Carburetor and Timing help
Look on the left side of the carb as you face it from the front. With the engine off, turn the throttle linkage so that if the engine were running you would speed it up to about half throttle. The throttle cable is connected to the primary shaft on the carb, that is the one you should be turning. Locate the secondary shaft which is in front of the primary. It should have a small triangle shaped piece of metal attached to the end of it and another piece of metal going back to the primary shaft. With the primary shaft in the half open position, try to turn the secondary shaft by turning the small triangle piece on the end. When you try to turn it, you should feel spring tension on it and it will try to return to the position it was in before you attempted to turn it. If you don't feel any spring tension when you turn it, either the spring on the primary shaft is broken or unhooked.You gonna race that thing?
Every thing on the carb should be capped off.
Besides brake booster, 2 lines to the dist and the cruise control.
There are 3 fuel lines 2 are capped...is one of them supose to vent?
I will try and test fuel pressure in the morning.
Right now if I rev the engine and release the gas the engine will die.
Could this be spark related?
Problem is gettung worse.
Fumes burn eyes when car idles.Slacker Sam
I've attached a picture I did for someone else showing the carb. In the picture, the hose marked "D" should be connected to the pressure side out on the fuel pump, hose letter "B" should be capped. I plugged the top of the bowl vents on my carb so if the car rolled, gas wouldn't run out there. Your vents are open on your carb so you can cap that fitting. The letter "C" fitting is where you connect your distributor vacuum advance. When you say 3 fuel lines, are you talking about the carb or the fuel pump? The carb has only one fuel line and it's marked "D" in my picture. If you are using the stock B3 fuel pump, that has 3 lines. One suction, one to the carb, and one return to the tank. Another thing you might try is blowing through the return line and make sure it is open to the tank. Take the gas cap off the tank first. I won't be available next Monday, but as far as I know, I should be home Tuesday morning.
I put this in the Weber Carb Tuning thread, thought it might as well go here too:
hey festy 46,
due to aerwork issues we were not allowed into canada.... long story. so we will not be headed east. we are now in iowa headed to MN the n UT. thanks for offering to hel us out on tuesday, but we wont be able to make it.
hope to find carb help soon. 23mpg is getting expensive.
samSlacker Sam
seems to me if you just take off a couple days stop by somenes place and get the car lined out right thenyour wouldn't be replacing engines left and right.idc how new a motor is if you put 20,000 miles on in no time with underlying problems your doing more like 100,000 good miles.by the time u spend money and time to replace engine you could of got it fixed long before needing an engine and probably saved money and time in the long run.there is no such thing as a rolling mechanic. you know someone to work on it while you are driving down the road.lol would be nice tho
Get that fuel pressure checked. I think it's a good possibility you have either too high fuel pressure, a leaking float valve, or a float level set too high.You gonna race that thing?
