Carburetor and Timing help
I see you have those vacuum lines tee'd together. I wonder if they might be interfering with each other? Maybe have them come from separate vacuum sources on the intake manifold.Originally posted by yogaslackers View Post[ATTACH=CONFIG]13928[/ATTACH]90 Festy (Larry)--B6M (Matt D. modified B6 head), header, 5-speed, Capri XR2 front brakes, many other little mods
alot of guys have them teed and they run fine. where did u find just the vaccum pod to replace on dizzy.
I myself use just the bottom port on dizzy it advances the farthest. and I don't run advance of the intake port. I run it off the port on the carb or ported vaccum.
hope this helpsLast edited by 1chrisapple; 09-27-2013, 07:41 PM.
^ This.Originally posted by 1chrisapple View Postalot of guys have them teed and they run fine. where did u find just the vaccum pod to replace on dizzy.
hope this helps
Intake manifold ports sometimes fail to deliver good vacuum.
But There is a thread on here where some have said BOTH ports on the disty provide advance. Chris is one and so did Zoom tee his vacuum lines and said it runs better.
I, myself, am going to try the tee.
I have one line to carb and one to manifold now. Going to tee both to carb and see what happens! :smile:
BTW, I have the weber 32/36 carb.Last edited by drddan; 09-27-2013, 08:29 PM.Dan
Had to buy a rebuilt dist to get the vacuum pod.... 236.00 crazy price for what it is. I just installed a wide band sensor... found out I have been running rich in the 10's now i have it set to 14.8 or so it bounces between 12.6 and 16. I hope to gain a better understanding of my driving habits with this tool. Right now I am having trouble setting the Idle and fast idle, while keeping the F?A at 14.8. any thoughts? do I need stronger spark?
thanksSlacker Sam
Escort carbs are WEBER carbs and use the same jets as a Weber 32/36, which can be gotten on Ebay, or any VW buggy shop, as most buggy's use Weber's on the engine.
On Ebay, look for a seller that goes by the name "Rapid Carb".
Great guy and will answer any Q's you might throw at him, too! Jets are about $5.00 eachLast edited by drddan; 10-02-2013, 03:54 AM.Dan
