Carburetor and Timing help
  • #76
    How do i set cam timing marks at 12 and 3 but how do i know when block it tdc? Use the timing mark on the pulley?
    Slacker Sam
    • #77
      How do I find post #73... I dont understand searching on this site... sorry.
      Slacker Sam
      • #78
        once you remove the dust cover to the timing belt, you can peek down to the crank cog and there's a mark on it that lines up with a notch on the oil pump body (helps to have a good flashlight). use that mark for TDC.
        • #79
          where you at now SAM? Wow, I'm very surprised no one in Florida has chimed in to help you..
          • #80
            Here is the how to on the timing belt:
            The Festiva Store
            • #81
              Im in Denver
              Slacker Sam
              • #82
                The ign timing in Denver might have to be set differently than Florida if you can't find the barometric connector.
                • #83
                  well ill be in las vegas in 9 hours...
                  Slacker Sam
                  • #84
                    It's amazing to me how you can crisscross the country in a car down on power that doesn't have a whole lot to begin with!
                    • #85
                      Patience. Little power is right 35mph out of Denver... for 7 miles, 85 mph on the down hills. think the cop will buy average speed limit argument?
                      Slacker Sam
                      • #86
                        man I have zero power on up hill... have to be in 3rd to go anywhere...
                        Slacker Sam
                        • #87
                          Lots of site members would like a crack at fixing this thing if you could stay in one place for awhile.
                          • #88
                            That it's running at all on long trips makes me still think timing--either cam or ignition. This should be easy.
                            • #89
                              I think putting the degree wheel on both the crank and the cam will turn up some
                              marks that are simply wrong. Setting the ignition advance curve inside normal
                              limits should complete it.
                              • #90
                                help
                                choke,s stuck probably get another choke,or see if u,can get a weber dgv conversion fromPIERCE MANIFOLDS. weber dgv,s have no emission lines. when u,change or switch engines and carbs,you re flying on your own. any good mechanic,from a garage could help u. u just gotta find one.carb needs set up right. emission lines place d in proper plaves. is your vacumn advance hooked up? sorry you are flying blind.
