Originally posted by blueoval
weber carb details
Originally posted by blueoval View Posti'll use more commas if you just post on subject and on facts,how bout that?hows that sound?90 Festy (Larry)--B6M (Matt D. modified B6 head), header, 5-speed, Capri XR2 front brakes, many other little mods
georgeeb
Originally posted by georgeb View PostI have three and no room for another. I would trade my running EFI auto for a project carby in a heartbeat.
I know this is an old thread, but I just bought an 89. I had to remove cylinder head (blown head gasket) had it shaved, checked for cracks and cleaned up. Installed new clutch, and I have it back up and running but the previous owner has vacuum lines plugged everywhere, no line to dist vac advance and the car hesitates when I hit the gas, gotta feather it up from idle. Right now I have timing set at 3 deg BTDC to get some semblance of idle and throttle response from idle.
This is a stock carb and the original air filter housing and heat riser equipment is all gone. What vacuum lines do I NEED??
PLEASE someone help me with a diagram, you can email me direct. phisheenguy@yahoo.com
The bottom line on the dist. goes directly to the manifold, and the top one goes to a T that splits the lines between a vacuum heat valve and the EGR if I'm not mistaken, I cant find the diagram...
If you cant set the lines correctly, then you may set the timing at ~12 degrees, with this the hesitation goes away. Sometimes the reason why people plugged the dist lines is because the vacuum advance goes bad and leaks. I havent been able to find new spare for it, just the whole reman. dist.
WHERE DOES THE TOP VAC LINE GO TO WITH WEBER CARB SETUP, AND I AM DOING AWAY WITH ANIT-BACKFIRE VALVE SO WHERE DOES BOTTOM VAC LINE GO?Last edited by Kbaker2012; 02-22-2014, 11:11 PM.
Originally posted by Kbaker2012 View PostWHERE DOES THE TOP VAC LINE GO TO WITH WEBER CARB SETUP, AND I AM DOING AWAY WITH ANIT-BACKFIRE VALVE SO WHERE DOES BOTTOM VAC LINE GO?
