Speedo calibration
  • #16
    I swapped in a low ratio rear diff and 5 speed tranny into an old Ford P/U which caused the speedo to read 20% low. Which was what I was expecting (ie the engine revs 20% lower at highway speeds) but was fortunate to be able to choose from a variety of different aftermarket speedo gears in order to rectify the problem.
    Unfortunately that option is not available to Festys, even an Aspire speedo gear (from a manual tranny) is the same as for a Festy MTX and ATX. I suppose if speedo calibration was really important to you swapping over to an Aspire tranny or any tranny (MX3/323/Protege) that comes from a car without 21 inch diameter tires (ie 12" rims) would better suit a Festy speedo. Most Mazda stuff from the late 80s and early 90s had 175/70-13s which are 23" in diameter.
    • #17
      I might have found the answer... if so it will be about $100. Not ready to accept that as the only.
      I tried the aspire gear. The shaft was too short and didn't reach
      HULi ---------------------------------------------------------------------------> Any-where, any-way, any-time.
      "CL4P-TP" - 93 Festiva L
      • #18
        Okay... here it is...
        Down at the bottom of the page, $72 ratio adaptor; if you are running aspire tire size you want to speed up 11%.
        EVOSTOTO kini hadir sebagai situs bandar toto macau terlengkap di indonesia, memberikan peluang menang dan juga memiliki prediksi yang sangat akurat.
        • #19
          Temporary speedo fix!
          • #20
            I like your new speedo!!
            -Rafe-
            Things I have for sale.
            Random Festiva Parts
            • #21
              Its like a drop chart for your longrange rifle!!!
              • #22
                I contacted them a while back. They said they don't have an adapter for our cars.
                http://www.partshp.com/speedometer_gears.htm
                • #23
                  Really? Crap. I have been trying to call. Guess they got messed up by the storms.
                  • #24
                    Hi I'm new to all this. I just got my first festiva,of course having speedometer psroblems. Gps sounds like the way to go for for now. Too bad, though now I know not to take it to a shop since they probably couldnt calibrate it either.
                    • #25
                      I know that my festiva can go up to 47 mph in 3rd but idk if that's wrong.... and that's running 155/70/12 tires
                      Doug's Daily Driver (Dad): '91 Ford Festiva L Manual "Old Yellow" got with 40,xxx mi... about 52,xxx mi. give or take now
                      Austin's Daily Driver (mine) : '91 Ford Festiva GL Automatic "Whitie III" W/ 0.40 over aspire engine from '94 Aspire "New Blue" rebuilt 92,xxx mi. then... about 96,xxx mi. or more now (on body)
                      Doug's work car: '95 Ford Aspire Manual "Whitie II" w/ swapped stock aspire engine from '95 Silver Aspire and has
                      it's 5th transmission! 75,xxx mi... now with about 130,xxx mi.
                      Sold! '89 Ford Festiva Manual "Gaystiva" (sold to my Uncle) - got with 163,xxx..... now 163,xxx Sold!
                      TRANSFERRED! '89 Ford Festiva Automatic EFI "one hit wonder" Given to
                      bolokid - got with 210,xxx ...... now with 210,xxx miles TRANSFERRED!
                      '94 Ford Aspire SE Manual "Assfire" - got with at least 350,000 mi
                      SOLD! '90 Ford Festiva L Manual look for Narion (or click the username) it's new owner on the forum! - got with 193,xxx miles... now has 193,xxx miles give or take SOLD!
                      R.I.P '91 Ford Escort GT w/ bad engine..... stripping for parts then off to the scrapper!
                      R.I.P '91 Ford Festiva Manual "Lil Red Rocket" bought brand new in 1991 with ~120 mi... ended with 227,xxx mi.
                      R.I.P '97 Ford Aspire 4 Door Automatic "Ford Metro" parts car - got with about 144,xxx mi.... ended with 144,xxx mi
                      R.I.P '95 Ford Aspire Manual Silver (one owner and one family car) got with about 50,000 miles ended with about 90,000 miles
                      R.I.P '94 Ford Aspire Manual "New Blue" got with 150,xxx.... ended with about 200,xxx (it's engine is the .40 engine in my GL)
                      • #26
                        Just 47 in 3rd? I've shifted into 4th from 3rd many times at over 65 mph.
                        Jerry
                        Team Lightning
                        Owner of Team Lightning
                        93 L Lightning. BP
                        • #27
                          Asking here too... need tooth count on the speedo gear and the gear in the manual transmission... anyone know?
                          Sent from my DROID RAZR HD using Tapatalk
                          • #28
                            would it be feasible to hold the shaft that the speedo needle is attached to and re-position the needle by pushing it CW or CCW on the shaft the amount of MPH you are off? would it stay where you put it? i'm just guessing it's a pressed fit. and i guess if you have to turn it CCW you'd have to remove the resting pin. i'll try this on a junker cluster.
                            • #29
                              ^ I did this to my old Rust bucket a while back . Just moved the needle to be correct at 55mph since that is most of my driving. Therefore above and below will be a little off but much less so. It worked for me. Like said above. the needle motion isn't linear so please take that into consideration. LOL
                              Kinda the same concept with the temp gauge too. Probably why sooo many temp guages are off compared to others. The needle "can" be installed a little off at the factory i'm sure. Sounds logical anyway. lol
                              -Bryant
                              • #30
                                Downloaded a speedometer app off the android game store. My speedo is off 2 1/2 km/h.
                                1993 Festiva L "Wendy" BP n' stuff
                                2013 Mazdaspeed 3 "The Kraken" -Stock.
                                Dave Forget
