Went back out with the LED test light to the injector harness with all 4 connectors unplugged. The YEL/BLK is the 12V constant and that works (Green LED key OFF, red when key ON or START).
the GRN/BLK should be the ground wire. My expectation is the LED will not light up when probed, and would blink from off to green as the pulse signal was given. Am I correct in that? Anyway, when I tested it the LED did not light up at all with key OFF, ON, or START.
At this point I see nothing that would cause the injectors not to pulse and the ICM not to pulse except the ECA. The fusible links are good and (unless I misunderstood the test) the main relay works.
-toast
Yellow/Black should have 12Volts + at all times with the switch in the On/ Start position and will not pulse.
Green/Black is the negative wire going to the ECU and is the one that the ECU turns on and off.
-toast
