Well at the very beginning when I got the car back from my father, the water pump had been leaking a long time, spraying back toward the alternator, and eventually the alternator let go too. So I got the car back running, but with the alternator light on. Like I said though, the car ran. I then changed the water pump, alternator, and timing belt. Perhaps I did not disconnect the battery when doing the alternator? It was over 2yrs ago so I dont remember. Still, wth the key OFF I dont know how ypu could fty an ECA by messing with an alternator.
I too believe that with no switching signal getting to the ICM and no pulsing signal getting to the injectors, the ECA is the likely culprit. Add to it the lack of a check engine light and Im very suspect. If it were fusible links or the main relay, I would expect to see more wrong. Plus he tests I did appear to confirm the links are good, right?
Getnpsi just loaned me a 1.6L ECA so I can substitute now. The main question now is, how do we know tyere is not a short or bad ground that will either damage this ECA or duplicate the problem due to its ground still being bad? Id hate to have to buy two ECA's.
Im not surprised at the ECA just going for no apparent reason. This JUST happened to my van when the engine bay became heat soaked. The CEL would not come on and I would get spark but no fuel until setting a fan in front of the computer fr 15min. After much troubleshooting I got a computer and it runs fine. Ive also had multiple CDI boxes go bad on 1980's motorcycles. True, the Festy computer is in the cabin and should be free from the environment, but the wizzardry can leak out of those magic boxes for no reason.
I share ypur opinon though that the home mechanic too often STARTS at the computer and works back. I understand we usually must test EVERY component associated with the computer and, finding them all good, condemn the computer. Thats why I havent given up. Thats also why I will never own modern cars or anything with a CAN-bus controller, making these types of checks impossible to do.
Anyway, can you think of any reason we should fear plugging a new ECA in for testing? Obviously I would disconnect the battery during the swap. Although my testing has been haphazard and confusing, I believe the ECA is the culprit.
Sorry forcthe spelling, im on my phone again and cant see what Im typing.
-toast
-toast
