Would a distributor from a Ford Capri XR2 fit our B3?
Question of the Day
Does anyone know how to customize a horn button?
How would one go about inserting a Festiva logo inside?
Does anyone know if it is possible to replace failing wiper pivot grease cups with ones other models? I would like to know if I could buy the plastic cups alone from PHWL Autoparts.Last edited by bravekozak; 01-30-2016, 07:23 PM.
Wondering if the "question of the day" thread defeats the purpose of the search function. Doesn't the search look at subject lines? I don't mind seeing individual threads for all these questions if it helps find info. in the future. ?????Last edited by WmWatt; 01-30-2016, 08:30 PM.Original owner of silver grey carburetted 1989 Festiva. 105k km as of June 2006. 140k km as of June 2021.
I wonder if these Pro-bolts will make my Festiva go any faster?
They are the only sexy wide flange valve cover bolts I could find.
Which ones should I buy? The sexy gold ones or the clear anodized ones?
Hmmm.
Anything is better than the ugly rusty ones.
How about hteir aluminum hose separator brackets?
Titanium nuts?
I will definitely pass on their spiked head bolts.Last edited by bravekozak; 01-01-2017, 09:20 PM.
Originally posted by bravekozak View PostWould a Mazda MX-5 rad cap fit our Festiva rads?
There's only a handful of rad cap styles, most JDM derived vehicles use the same type.Trees aren't kind to me...
Originally posted by bravekozak View PostWhat is the tab in on this rad cap for? Just another way to release pressure?
Yes it will release most of the pressure without having to turn the cap by hand, keeps you from getting a face full of hot coolant. I would recommend using a heavy glove or something because they will still release some hot liquid around the edge of the cap when you pull the tab.
Originally posted by Stinsin63 View PostYes it will release most of the pressure without having to turn the cap by hand, keeps you from getting a face full of hot coolant. I would recommend using a heavy glove or something because they will still release some hot liquid around the edge of the cap when you pull the tab.
Sent from my SM-G920W8 using TapatalkLast edited by ryanprins13; 03-06-2017, 08:08 PM.
