When the front wheels are up in the air with the transmission in gear, and you rotate one wheel, the other wheel rotates in the opposite direction. Why?
Question of the Day
So that your tires don't get eaten when you take a turn. When turning, the inner wheel rotates slower than the outer wheel. The spider gears in the transmission make up the difference. When the diff is still (in gear), the spider gears turn the other wheel opposite of the one you're turning. They're also responsible for one wheel wonders, which will blow them up in a short while.Originally posted by bravekozak View PostWhen the front wheels are up in the air with the transmission in gear, and you rotate one wheel, the other wheel rotates in the opposite direction. Why?-Zack
a late contribution to the sail plate debate. you'll notice there is no listing for the RH inner plate w/manual mirrors. so a question within a question. are the only festivas that came with left and right mirrors in 88/89 the LX with electric mirrors? were manual passenger mirrors only equipped on the 1990 and up GL? i'll have to look at the 1990's parts list. and another question within a question. why would the plates be different between an automatic and manual trans car??
I looked up the pride bolt on 4GREEN and they have a pic of the bolts you got. not only too short but they are fully threaded. what up widdat? i'm going to order the Avella bolts and see what they look like. only $1 ea. KB45534112B. also, the 121 bolts/nuts are still available from mazda here in the states. bolt is H00133302. nut is B03728091. the mazda bolts are over $5 ea. I don't know if Japanese steel is 5X better than Korean steel.Originally posted by bravekozak View PostThanks. Do not buy the Kia bolts from Four Green because they are too short.
I just check the triple relays that I pulled from a Festiva ealier this year at LKQ and all three are 7J28.Originally posted by bravekozak View PostNew question regarding the factory A/C relays in the rubber boot below the battery.
Are all the relays the same (2G05) for both the triple (automatic trans) and dual (manual trans) A/C relays?
I think in physical size and shape they are. and they are all 4 pin and SPST N.O. as best I can read schematics. the WAC contacts are downstream of a 10A inline fuse and the other 2 downstream of a 15A. I have a GL w/air and auto in a rented garage. maybe i'll take a look tomorrow.
Number on Relays is 056700-5260
Ebay listing with explaination:
http://www.ebay.com/itm/Mitsubishi-Subaru-Kawasaki-Lexus-Honda-replacement-Japan-RELAY-for-056700-5260-/130984224149Last edited by 1990new; 09-27-2013, 08:10 PM.
Thanks. That is the sane number on my relay. It has a 22A rating. I will check the wiring diagram to confirm it is on a 30A circuit.
New question, regarding weatherstips for quarter windows. Why are there two part numbers for these weatherstrips? I cannot see any reason why the same weatherstrip could be used for both sides.Last edited by bravekozak; 09-27-2013, 08:51 PM.
I believe they are premolded to some extent therefore different for each side.Originally posted by bravekozak View PostNew question, regarding weatherstips for quarter windows. Why are there two part numbers for these weatherstrips? I cannot see any reason why the same weatherstrip could be used for both sides.
Sent from somewhere west of here via Tapatalk!Ian
