But runs and starts fine the rest of the day. What could it be??
Hard to start first thing of a morning
If you have put new wires on it make sure all of them are seated good. I know mine were hard to heat seated properly anD caused some intermittent misses till I re did them
Sent from Kingston Ga from my hillbilly handheld90 festy with 92 FI motor. Digital camo paint. BHAF. short throw. currently 47 MPGs
Try disconnecting your engine coolant tempature sensor and see if it makes any difference. My started to go and caused ALL kinds of weird issues. It will throw a code when disconnected, but will clear up as soon as you reconnect it.
...Although thinking about it, it will be hard to diagnose as it will go to default values in the computer that will probably make it hard to start as well. It may make a difference though, at least enough to pinpoint the problem. At any rate its a cheap part worth checking.- Form should follow function...
Originally posted by logan View PostThe sender for the gauge is removed from the car maybe that has something to do with it??90 Festy (Larry)--B6M (Matt D. modified B6 head), header, 5-speed, Capri XR2 front brakes, many other little mods
Vaf?Dan
Vane Air Flow sensor.
Located in the air tube right next to air filter. Its the metal box thing. Has a vane flapper type thing inside. Try cleaning it and make sure the vane moves freely.Last edited by drddan; 10-02-2013, 12:07 PM.Dan
Originally posted by TominMO View PostGauge sender won't matter, and coolant temp sensor for the ECU shouldn't matter either until the car warms up.Last edited by SiliconSoul; 10-02-2013, 12:17 PM.- Form should follow function...
I think it has to do with contraction and expansion. Were mine failed was where the plastic plug part of the sensor goes into the metal body of the sensor. It starts to separate and get a bad connection as it heats up / cools down as well as vibration. Like I said, it is pretty easy to disconnect and see if it makes any difference.- Form should follow function...
Originally posted by SiliconSoul View PostI think it has to do with contraction and expansion. Were mine failed was where the plastic plug part of the sensor goes into the metal body of the sensor. It starts to separate and get a bad connection as it heats up / cools down as well as vibration. Like I said, it is pretty easy to disconnect and see if it makes any difference.
