I saw in your photo last night that you have a FUSIBLE LINK on the left side missing- don't know what exactly that goes to offhand, but you might try making a connection there-
they are the RED WIRES next to the battery on the side of the engine compartment beneath the strut top- there's three of them and you're missing the left one
there may be connectors down in the terminal and the wire gone, or you may have to buy connectors and make one of your own with similar guage wire as the others-
someone here suggested PAL fuses to replace the fusible links-
haven't done that yet myself- but had fusible links loose and NO START-
check that left fusible link under the hood
in fact- check all three and clean the connectors
