Note: When you tighten the housing bolts for your thermostat...limit
the tightening to about 150 inch-pounds. I've messed up two housings
before and, since it's getting more difficult to find these parts..use
caution. Also tighten the top, then the bottom, then the top, then the
bottom progressively. I always end up sweating a little when I'm tightening
mine up..don't want to break it again!! Good luck!!
