2nd gear Pull BP
    Bondo,I was looking at your pics.The one of your timing belt,is the photo strected? Cuz your timing belt looks like its loose? Otherwise looks like you'll be ripping up the island with your BP for sure.:thumbs_up:
      Thats a bummer I had a bunch of choices to pick from for compression but I took the stock 9:1 haha because I taught it would be good for boost. But thats awesome Im glad I can take it to 20psi because that was my goal, I plan on getting into 11's. And for head work a good port, super tech valves and valve seals, maybe some race cams, I know its gonna take more than power to get to 11's but Its a start. Also mega squirt for sure
        Was that the picture from when the Valve cover was gold or black? And thanks man! People trip down here that I did this to a festiva haha all my friends have hondas and Im the only guy that rolls around with the blue festiva, but my car got pretty known down here, civics fear my car haha
          and a trans to handle the abuse, the G-series seems to be good for up to 350hp (about 260 lb-ft) before it goes boom.
            haha yeah a G series is a gurentee, and a good LSD would be cherry to, Do you know anyone that makes mounts for a G series to bolt up?
              there's another member her that used to offer to make a crossmember that would allow a bolt in G-series solution. he's from Cali. drawing a blank on his name right now but i know it had g25mr in it.
                Hopefully he pops up here haha that would be sick, And do you know if the axles have to be from a 323?
                  Most people use the XR2 axle set. There are 3 pieces. The drivers side axle, the half shaft and Passengers side axle.
                  Jerry
                  Team Lightning
                  Owner of Team Lightning
                  93 L Lightning. BP
                  • #24
                    This is the person mentioned above along with a link to the part out of his car.
                    http://www.fordfestiva.com/forums/sh...-with-shipping!!!!!!
                    Jerry
                    Team Lightning
                    93 L Lightning. BP
                    • #25
                      ^ yup he is parting that sucker out.
                      You can use rio axles too. Easier to find and way cheaper
                      • #26
                        • #27
                          Gold-
                          • #28
                            I wish I had the money for those right now! haha hopefully they dont sell, that would make the G series swap alot easier
                            • #29
                              Gold-
                              That was before I rebuilt it but I did look at the pic and it does look like its loose but it was a fisheye lens to tho, A timing belt should have how much play?
                              • #30
                                Originally posted by bobbyspider View Post
                                i have one on my phone but havnt got it off yet. your vac lines control your vics so make sure they are hooked up. mine all of a sudden started feeling slowerish at one point then i checked the vac lines going to the vics actuator and it was broke, hooked it back up and felt a difference. if your vics isnt hooked up tie open the vics butterflies, but def hook the vics up when you get a chance if its not
                                Alright Ill definitely check that, Thanks. I just got a new vics solenoid to (really expensive). haha does your accelerate around the same as mine in the vid?
