Festy dyno vid 302 hp
  • bhearts
    replied
    Gotta love that v band. It makes mocking up a down pipe a diy instead of those strange oval shaped outlets.
  • Flyin4stroke
    replied
    Yeah just a big eBay. See if it spools.
  • bhearts
    replied
    A new turbo?
  • Flyin4stroke
    replied
    Yes.
  • bhearts
    replied
    Are you still running the oem crossmember?
  • Advancedynamix
    replied
    No pain no gain!
  • Flyin4stroke
    replied
    this may hurt a little.
  • Advancedynamix
    replied
    Originally posted by bhearts View Post
    Besides being 1/8th larger displacement. Does the bp have anything on the b6d?
    Yeah, the head flows better, and there are several different head options. There are more aftermarket cam options, there are better intake manifold and exhaust manifold options, the crank is forged and the block is set up for a girdle across the main caps and a nice windage tray.
    It's a stout engine, but suffers from an unfavorable rod ratio (mazda wanted to keep the height of the engine low, and short rods were necessary for this). This rod ratio is the root of the BPs tendency to shatter hardened parts like oil pump gears and transmission components, and causes traction issues at lower TQ numbers than the B6 engine. Both engines use the same rods, but the b6 has a shorter stroke, resulting in a more harmonically stable engine.
  • bhearts
    replied
    Originally posted by Advancedynamix View Post
    The weight of a bp will be hardly noticeable, and most likely an advantage because it's in the right spot. A BPT is not much heavier than a b6t. The BP is harder to get to hook up though, but easier to make bigger numbers.
    Looked like it was a couple years old, just the 400hp one, not a Nismo or anything, stock exhaust too. There is one in my complex that is 700hp, and not much can roll on that thing.
  • Flyin4stroke
    replied
    I'm not sure Charlie, maybe sonic will have to make an appearance. You can pretty much drive it by spinning the tires to turn lol the car is stupid fast in a straight line.
    Cone filter, Reich Ecu, open downpipe, 174hp on mustang dyno.
  • Advancedynamix
    replied
    Tweak only spins in the rain, and that's only when provoked to do so, but that's only 180hp. What was done to your b6t Mike?
    I want to find the perfect balance of TQ for the festiva chassis. It would be fun to put some road racing slicks on Sonic and see if that much TQ could be used on the road coarse. What do you think Mike?
  • Flyin4stroke
    replied
    I've had a b6t and bpt. The b6t was a lot less tq. The bpt will blow the tires anytime. The b6t would just spin up top. It was still fun and I love being light weight. But I just pull my backseat and makes up for the difference in weight lol. The extra power is sweet. Still could go more.
  • Advancedynamix
    replied
    Originally posted by Fecomatter View Post
    That's 180 b6t hp right? I assume bp numbers are slightly different because of weight.
    A new gtr?
  • mikemounlio
    replied
    I want to finish my up so bad it's crazy! But I'm gonna take my time and do it right and one time!
  • bhearts
    replied
    A new gtr?
