Festy dyno vid 302 hp
  • Damkid
    replied
    Originally posted by Flyin4stroke View Post
    Yeah I don't get why people over complicate things. If it's not broke don't fix it.
    Exactly!!
  • Flyin4stroke
    replied
  • Advancedynamix
    replied
    Originally posted by bhearts View Post
    What's the key to preventing that?
    You don't want to prevent it if you want traction. The Festiva suspension is designed to flex and isolate the chassis from TQ fluctuations, while still allowing the suspension to travel in a natural rearward arc as it absorbs surface irregularities. In short, the festiva front suspension is an engineering marvel. Replacing it with A style control arms is like putting leaf springs on your 2016 mustang. The Festiva front suspension is a design used by cars such as the Porsche 911. The sway bar is tuned to work with the weight of the car. If you make this more rigid, you'll have inconsistent traction.
    The part of the chassis that holds the sway bar can use some help though. That was designed for about 100ft.lbs of TQ. 300 ft.lbs is pushing the envelope a bit.
    I wish we could mount a couple video cameras to Sonic to measure the front wheel deflection when Mike launches. I'm very interested in measuring that with over 250ft.lbs to the ground. I'd love to build a better front end, but it's hard to improve this design. I'd like to built drag links that absorb the TQ load like the stock sway bar does, but that's easier said than done.
  • bhazard
    replied
    A few of the guys have fitted BF A arms in and set up traction bars. Which lets you eliminate the sway bar.
  • Fecomatter
    replied
    Yea, I would do the lower rad support mod. It costs 25 bucks in steel, and ~10 bucks in welding wire. it is significantly more rigid than OEM.
  • bhazard
    replied
    Or just build the front end up
  • Flyin4stroke
    replied
    Turn the boost down.
  • bhearts
    replied
    Originally posted by bhazard View Post
    Your poor control arms are gonna be flopping around everywhere
  • Flyin4stroke
    replied
    That sounds fun sorta.
  • bhazard
    replied
  • Flyin4stroke
    replied
    Just some slicks.
  • bhazard
    replied
    You better have some good body and front end mods to put that power to the ground
  • ZephTheChef
    replied
    Exciting numbers! Here's to hoping you slap a 62mm beast on there just for wow factor.
  • Flyin4stroke
    replied
    I drove home turbo clankin. I've got something bigger in the works. [emoji48] 400whp sounds fun for this car. We know it's doable why not.....
  • drddan
    replied
    Saw this on FB. Great job Mike!
