1993 Festiva L progression thread
  • Runs and drives now!!!
    Got the idle adjusted to where it should be, and drove it around the yard some. Seems to be running good feels good to finally get to drive it!! Not much left before it hits the road.. just have to install the aspire tie rod ends, fix the starting problem, work on the brakes a little more, and thats about it!
    -85' Nissan Sentra 5 spd.
    • Trick looking car! Glad i did all of the work!
      I'm telling you the whole starting issue is the park neutral switch on the trans....someone is bound to have one lying around.
      • Originally posted by festivaWES View Post
        Thanks Wes! and thanks a bunch for all the work you did on it!! I made a WTB thread about the switch and PM'd some people about it, but no luck yet..
        • I'd get that one from 66 but the day i made it over there they had crushed it already.....really didn't have much left of it basically a smashed front end and a missing rear. Tach cluster though.....
          • Nice Fred! Glad to hear you can drive the car now! Did you fix the balance of the motor too? Did you finally figure out why it was tilted to one side?
            -Josh R
            • Originally posted by 91blufestiva View Post
              Not yet, pretty sure it's the rear trans mount, this ones busted and in need of replacement..
              • Ah We'll fix all that and the tierod ends when i come up there for my 4 speed, aspire swap, b6d, the list goes on and on!!
                  Yep!
                  • Auto and manual passenger side engine mounts ARE different.
                    That is why my engine was slanted so much, you can clearly see the difference in this pics:
                    Manual:
                    Auto:
                    I thought I had the right mount, since that was the mount that was in with all the L+ parts.. someone must have put the wrong mount on that car somewhere along the way..
                    • If I hadn't drank so much beer, I bet I could of spotted it!
                      • Originally posted by Ford_For_Life View Post
                        Manual:
                        Auto:
                        That would explain the lean. :shock: Can't wait for you to get that thing on the road. Keep at it!
                        1988 L - 232K miles Batstiva
                        1989 L - 247K miles Slick
                          :lol:
                          Yep, I can't wait either!
                          • Thats strange, I never noticed the difference in the P/S mounts before between the auto and manual. My b6 car was originally an auto. ( I think the auto tranny is in your car now ) I used the original auto mount on the b6 motor with the five speed swap and it seems to fit perfectly. No lean at all. I went out and compared an auto and manual and it seems like the P/S mount shouldnt matter as far as the tilt goes. They are just different. Maybe you just have to use both the motor mount and the matching block bracket for it to be right. Maybe you just mixed an auto bracket with a manual mount.
                            • Originally posted by freshtiva View Post
                              Yep the trans from your B6 car is in my green car now. It looked like to me if I switched P/S mounts it would raise that side to where it should be. Right now the pass side sits too low. I'll get it straightened out somehow, the engine in the car came from a auto car (that white L+ I have) so I think the block brackets would be correct. I should name this car "Muttstiva" :lol: since it has parts from so many different cars on it..
                                That would confirm my theory. You have the auto block bracket with the manual motor mount.
