• Accelerator Pedal and Linkage
    • ADJUSTMENTS
      • Accelerator Cable Deflection
      • Wide-Open Throttle Position
    • DESCRIPTION AND OPERATION
    • REMOVAL AND INSTALLATION
      • Accelerator Cable
      • Accelerator Pedal
  • Accessory Drive
    • ADJUSTMENTS
      • CAUTION:
        Proper tensioning is important to belt life and proper operation of the driven components. A loose, slipping belt will rapidly glaze and may cause a noise or improper component operation. An overly tight belt exerts unnecessarily high loads on component bearings.
      • Generator Drive Belt
      • A/C Compressor Drive Belt
      • Power Steering Pump Drive Belt
    • SPECIAL SERVICE TOOLS/EQUIPMENT
    • SPECIFICATIONS
  • Air Conditioning
    • A/C Heater Control Assembly
    • A/C Refrigerant Pressure Switch
    • A/C Relays, DESCRIPTION AND OPERATION
    • A/C Relays, REMOVAL AND INSTALLATION
    • A/C Switch
    • ADJUSTMENTS
    • Air Distribution Plenum
    • Air-Conditioning System
    • Blower Motor
    • Blower Resistor
    • Blower Switch
    • Charging from Small Containers
    • Cleaning a Badly Contaminated Refrigerant System
    • Compressor and Clutch Assembly
    • Condenser, DESCRIPTION AND OPERATION
    • Condenser, GENERAL SERVICE PROCEDURES
    • Condenser, REMOVAL AND INSTALLATION
    • Condenser Fan (ATX vehicles)
    • Control Assembly
    • DIAGNOSIS AND TESTING
    • Diagnosis Charts
    • Evaporator, DESCRIPTION AND OPERATION
    • Evaporator, REMOVAL AND INSTALLATION
    • Evaporator Core
    • Evaporator Housing
    • Expansion Valve
    • Flushing a Refrigerant System
    • Fuses
    • GENERAL SERVICE PROCEDURES
    • Heater Core
    • PINPOINT TEST AC: AIR-CONDITIONING
    • PINPOINT TEST RF: REFRIGERANT SYSTEM PRESSURES
    • Receiver/Drier, DESCRIPTION AND OPERATION
    • Receiver/Drier, GENERAL SERVICE PROCEDURES
    • Receiver/Drier, REMOVAL AND INSTALLATION
    • Refrigerant Hose (Discharge Hose)
    • Refrigerant Line (High pressure)
    • Refrigerant Line (Low Pressure)
    • Refrigerant Pressure Switch
    • Refrigerant System Purging to Remove Air and Moisture Vapor
    • Refrigerant System Service
    • SPECIFICATIONS
    • Safety Precautions
    • Service Gauge Ports
    • Service Ports
    • Symptom Chart -- Air-Conditioning
    • System Charging
    • System Discharging With Recovery System
    • System Evacuating
    • System Inspection -- Air-Conditioning
    • Testing A/C Performance
    • Thermostatic Expansion Valve (TXV)
    • Thermostatic Switch, DESCRIPTION AND OPERATION
    • Thermostatic Switch, REMOVAL AND INSTALLATION
    • Visual Inspection
  • Air Intake System
    • Air Cleaner Unit
    • Air Filter Element
      • Air Cleaner and Duct System
      • Refer to the « Powertrain Control/Emissions Diagnosis Manual, Section 12B (Air Intake Systems)» , for diagnosis of the air intake system.
    • Volume Air Flow (VAF) Meter
  • Antenna
