4WD festiva idea........
  • #31
    I plan on adding custom widened fenders onto the festiva. If the miata rear is wider thats great i wanted a wider track on the festiva so itll corner better. i plan on startin rally racing it in the future.
    • #32
      Wider meaning the width of the subframe/crossmember - if you put them side by side you'd see what I meant. Not talking tires here
      1991 Mercury Capri XR2 "GTXR2" BPT Swapped AWD Conversion
      Rocketchips!
      Bolt-on Weber Carb Adapters!
      • #33
        Originally posted by TominMO View Post
        What about bolting a Festy body to a Suzuki Samurai chassis? They are a lot more available than the Justys.
        If I remember correctly they had an independent transfer case too, that would make an engine swap easy, ( humm... V6!) or was that the geo tracker?
        (paperboy 23) 88 Festy Blue, aspire Engine/trans/efi swap,
        • #34
          Wouldnt the car have to be factory awd for you to rally it legally?
