I plan on adding custom widened fenders onto the festiva. If the miata rear is wider thats great i wanted a wider track on the festiva so itll corner better. i plan on startin rally racing it in the future.
4WD festiva idea........
Wider meaning the width of the subframe/crossmember - if you put them side by side you'd see what I meant. Not talking tires here1991 Mercury Capri XR2 "GTXR2" BPT Swapped AWD Conversion
Rocketchips!
Bolt-on Weber Carb Adapters!
Originally posted by TominMO View PostWhat about bolting a Festy body to a Suzuki Samurai chassis? They are a lot more available than the Justys.
If I remember correctly they had an independent transfer case too, that would make an engine swap easy, ( humm... V6!) or was that the geo tracker?
