My B3-T setup
  • No! You have to use to festy flywheel. Explain how the Suzuki flywheel would bolt to the Mazda engine?
    91GL BP/F3A with boost
    • Wasn't sure if the flywheel has the same bolt pattern or not. Thought you might have tried the flywheel too.
      • My B3-T setup
        He says that the swift flywheel is 8 inches and the festy is 7.125. It would never fit.
        1989 Ford Mustang GT 5.slow
        1996 Ford F-150
        • Originally posted by Flyin4stroke View Post
          Hence my misunderstanding with the grinding of the bellhousing.. All good.
          • Probably have to grind the bell housing to fit the larger clutch.
            1996 Ford F-150
            • ^Yes.
              Machine Festy flywheel flat, do some other things that I can't remember to mate the swift clutch to it, then grind the bellhousing so the clutch PP doesn't hit it.
              Or just buy a SPEC stage 2 and bolt it on and grind nothing. Mine was about $200 delivered from eBay. Still haven't gotten to start it up yet, though.
              • Gotta be careful with those harder clutches, they make it a lot easier to destroy the E trans.
                • True. I do have a couple extras, though I will be careful, and if need be fill mounts. I'll also have poly bushings on everything up front, so that should help.
                  • Wow old thread lol this almost makes me wanna Turbo my spire ..... i wonder how long the f3a would hold before you need a 5 gallon bucket and a push broom to collect your transmission lmao rofl
                    • The F3a is stronger than the stock 5 speed by far.
                      Theres a few auto cars with swapped engines on here including mine and it holds up fine. I will hopefully be feeding mine 250+ hp this year.
                      • Originally posted by bhazard View Post
                        So does that mean me killing my f3a offroading and pulling stuff mean i would have destroyed a
                        5 speed a long time ago? Lol
                        • did he ever say what ratio FMU he was using?
                          Tommy
                          WannaBimmer Build in Progress:
                          http://www.fordfestiva.com/forums/sh...-Festiva-Build
                          • Originally posted by dustinp View Post
                            Most likely. The auto is a lot stronger but nothing is bullet proof. A trans cooler should be used any time you're pushing it hard.
                            • Well i guess when my new trans goes in that old trans cooler off of the old ford pick up
                              I had is finally going to find a new home lol i knew i needed one i just never installed one lol
                              • Turbo updates?
                                bumpup
                                Any updates? Im anxious to know what your squeezing out of that little sewing machine lol
