No! You have to use to festy flywheel. Explain how the Suzuki flywheel would bolt to the Mazda engine?
My B3-T setup
My B3-T setup
Originally posted by jhntu View PostWasn't sure if the flywheel has the same bolt pattern or not. Thought you might have tried the flywheel too.Last edited by Flyin4stroke; 12-18-2014, 10:34 PM.1988 Ford Festiva "Sonic" BPT g25mr MS2 standalone ecu, FOTY '11, Best Beater FMV, Fan Favorite FMVI
1989 Ford Mustang GT 5.slow
1996 Ford F-150
^Yes.
Machine Festy flywheel flat, do some other things that I can't remember to mate the swift clutch to it, then grind the bellhousing so the clutch PP doesn't hit it.
Or just buy a SPEC stage 2 and bolt it on and grind nothing. Mine was about $200 delivered from eBay. Still haven't gotten to start it up yet, though.Any difference that makes no difference is no difference.
True. I do have a couple extras, though I will be careful, and if need be fill mounts. I'll also have poly bushings on everything up front, so that should help.Any difference that makes no difference is no difference.
The F3a is stronger than the stock 5 speed by far.
Theres a few auto cars with swapped engines on here including mine and it holds up fine. I will hopefully be feeding mine 250+ hp this year.91GL BP/F3A with boost
Originally posted by bhazard View PostThe F3a is stronger than the stock 5 speed by far.
5 speed a long time ago? Lol
Originally posted by dustinp View PostSo does that mean me killing my f3a offroading and pulling stuff mean i would have destroyed a
5 speed a long time ago? Lol91GL BP/F3A with boost
