Yea this rain is ridiculous, sun shining and hot as crap, out of nowhere in the matter of 2-3minutes storm clouds thunder & lightning, and fat rain drops that soak you before you can walk or run 20 ft.
2001 kia rio manual transmission swap?
2008 Kia Rio- new beater
1993 Festiva- Fiona, DD
1997 Aspire- Babyspire, DD
1994 Aspire - Project Kiazord
1994 Aspire- Crustyspire, RIP
Originally posted by jason_ View PostThe famous mitten.
30 miles north or so of grand Rapids.
Rained last night, sprinkled this morning so I don't dare gamble anything that's not water friendly unless it's certain.
Originally posted by zoom zoom View PostYea this rain is ridiculous, sun shining and hot as crap, out of nowhere in the matter of 2-3minutes storm clouds thunder & lightning, and fat rain drops that soak you before you can walk or run 20 ft.Some people like to read fiction,I prefer to read repair manuals. Weird I know-
BTW, a Rio shift linkage fits perfectly
Sent from my SPH-M930Festiva: Because even my dog can build a Honda.
Originally posted by JPT View PostI'm going through that right now, but the trams is going in.
Sent from my SPH-M930Some people like to read fiction,I prefer to read repair manuals. Weird I know-
Ooh, that means possibly the whole shifter assembly would swap in?Any difference that makes no difference is no difference.
- Likes 1
Originally posted by JPT View PostBTW, a Rio shift linkage fits perfectly
About an inch an a half too long
MIG/fluxcore welder>
I'm pretty sure the end needs clocked 90* too doesn't it? Or is that just for the G series swap? I remember having to flip the ujoint tho.Last edited by zoom zoom; 07-08-2013, 07:52 PM.2008 Kia Rio- new beater
Originally posted by shadetree View PostHow did the mounting work out for you jpt?
Got around the shift linkage length problem by relocating the shifter back. After mounting everything, I only needed an inch.
I'm using the stock shift linkage, rebuilt with pieces off the Rio one plus a Civic short shifter.
More to come when I get back from vacation.
Update
Ended up tweaking the mounts a bit and went back to the Rio shift linkage. It's a bolt in, but you will have to locate it back a bit if you don't shorten it (mine is now a touch more than an inch back).
Also, while I was at it...
These are STIFF!
I'm going to do the passenger side too.Festiva: Because even my dog can build a Honda.
Another update
After living with this transmission for a week, I have a few observations.
1). 5th gear is wonderful. I can ride around in 5th and from a little over 30 MPH, I don't need to shift with the B8. It revs a bit high on the highway (65 MPH is a little over 3000 RPM), but stepping on the gas will definitely put a smile on your face :icon_smile: The other gears are about the same as the Aspire trans I had, but 4th is perfect for slow cruising city streets.
2). This is an easy swap for anyone looking for something stronger than stock and can't find a G series with the intermediate shaft. The axles fit a little tight. At full suspension drop they are very close to binding up, but as long as you don't make it a habit of getting air with your car, it won't be a problem.
You'll have to make some cross member mods though. The stock rear mount has to go completely, you'll need to flatten out a bit of the hump in the rear (try putting a mount in the back and you'll see exactly where and how much). While I was at it, the plate on the cross member was removed also. The oval hole in the back happens to be right where a bolt on the rear mount will go. You could put a plate back there and drill a hole or use a large (LARGE) washer.
If you ever want to go back to an E series trans, with some washers, the Rio mount will fit on the back of an E series. The stock rear mount can be made to work on a Rio trans if you shave a bit off the case. I tried it and it fits, but the Rio mounts are way better and will place the transmission in the car in a better position.
3). The Rio linkage fits like it was made for the car. Its built better and has a support in the back that guarantees that your shifter won't fall down ever again. You'll need to drill two holes to use it. The only thing is it's a bit long. Two ways around this. Locate the shifter back a bit or shorten it. If you don't shorten it, using the stock shifter rod with the rest of the Rio setup works great and yes, a Civic short shifter will work.
It occurs to me that a Rio short shifter would be a perfect upgrade. It would fit like stock.
If you want to do this swap, you'll need the following parts.
The transmission.
The block plate for a Rio. My F series stuff went in the last scrap run, so I don't know if the F series block plate or flywheel will work (I have a feeling they will).
A Rio starter (F series might work).
New bell housing bolts if you want to lower the trans. The old ones will work. I lowered mine at first, but in the end, I put it back in the stock position.
Optional (but recommended by me). New flywheel and clutch bolts.
The reverse light/neutral start switch off of your current transmission.
Except for the mounts and cross member mods, this is your typical transmission swap. The only wiring to be done is the switch swap and lengthening one wire to the starter.
Any questions, just ask.Festiva: Because even my dog can build a Honda.
is it hydraulic and you do the entire rio transmission?
i know a couple guys on here only did the gearbox
And what cv axles?Last edited by RhodeStiva; 07-16-2013, 12:48 PM.;
www.facebook.com/rhodestiva ;
rhodestiva@gmail.com ;
'92 Festiva L M/T
'93 Festiva GL A/T
