Ultimate Street suspension guide
This is a sticky topic.
  • chiquito1228
    replied
    Any body else having problems with the ebay front coilovers not having enough travel.
  • Bratboy
    replied
    Do the front coilovers matter as to dpecs or brands,? Will they all just work?
    What brand do people recommend?
  • Tyler77
    replied
    Originally posted by Gdh_85 View Post
    Hey follow Canadians... Where did you guys purchase your coil over sleeves and springs? Trying to find the best price plus shipping options and I don't want to get stuck paying any B/S duties and or Brokerage fees.
    Hey gdh_85 I live in Chilliwack bc and I ordered my coilover sleeves and springs right from southwest speed in the states, as Mentioned in this thread.
    i couldn’t find a better price and duties/taxes was only about $35
  • krackerjack
    replied
    looking for photo of console for festiva i had a 91 with console saved it ..to sell any one have a photo of one
  • Gdh_85
    replied
  • theastronaut
    replied
    What is the reason we don’t use the rear mk2 coil overs?
    They are too long, the springs are too stiff, and the spring diameter is larger which limits wheel/tire width.
  • Gdh_85
    replied
  • angrychair
    replied
    Originally posted by Advancedynamix View Post
    If your shocks are making squeaky or grinding noises then you may have the top nuts too tight. The top rubber bushings only need to be squished a little bit (how much really depends on how old and hard your bushings are). If those top nuts are too tight, the shock can't articulate enough, and it will bend and flex the shock shaft. Those shocks go back and forth a lot when the car is being driven. That top mount NEEDS to flex easily.
    Originally posted by skeeters_keeper View Post
    The vw bump stops should be sanded to a relatively loose fit inside the spring.
    Between the two of you , you may have just saved me so much time.
  • blake4591
    replied
    You can drill and tap through the nut and put in a set screw to help hold it in place. I was planning on doing that for the rears on my car. I never got a around to it and haven't had an issue. That seems to be the general consensuses that they don't really move much once set with some preload.
  • Dragonhealer
    replied
    It's not an issue, it will stay where you adjust it.
  • Tyler77
    replied
    Hey I just received all my springs and coilover kits I from southwest speed.
    One question I have about the sleeve adjusting nut though.
    How does just the one work by itself? should there be two to lock them in place. It seems that just one would start to unthread or loosen after driving vibrations if a second one wasn’t there to lock in place?
    has this been an issue for anybody
  • ryanprins13
    replied
    An addition to the ultimate street suspension would be the spacers to adjust static droop in the rear. They are now available at the festiva store. See this post if your interested: https://r.tapatalk.com/shareLink/top...7&share_type=t
    Sent from my SM-G950W using Tapatalk
  • Dragonhealer
    replied
    Charlie should chime in, as I don't know if the lengths need to be different.
    with the B3 I would start with 130lb/in front
    And 120lb/in rear for a multi use car.
  • trbo95
    replied
    First off, thank you to all that have contributed to this. Great info! My apologies if this is not the place to ask this but I'm looking for recommended spring rates for a 1997 Aspire using the Advanced/Ultimate suspension. Multi purpose car with a focus towards track days. Thanks
  • ryanprins13
    replied
    Originally posted by navdoc101 View Post
    I have the Festiva Motor Sports Lowering Springs. Can I use these? I am only going to do the front .
    How large in diameter are they? I believe the lowering springs are only meant so the stock struts and not the coilovers
