time for paint and bodywork
  • That thing looks so nice good job.
    • hey what length and weight are those springs? i went with 7 but i think its to short. my top hat on the spring is pretty loose aroun the top i was going to use some kind of bushing to center the strut shaft better, did you have any issue with that? do you have any pics with the mounts off?
      btw did you have any luck with those origns? they keep binding and wouldnt sit straight between the strut a collar
      thanks
      Rick
      • 250lb 7in springs. The top hats that came with the sleeves were plastic. So I ordered a set.of aluminum ones. The hole was too small so I drilled them out to fit. Ill try to take more pics when I pull them out again. Origns? You mean the orings that center the sleeve? No didn't have a problem with them. As long as the sleeves not moving around I think its fine.
        Better Than Nothing Racing
        Way too many cars
        :woc:
        • thats what i used too where the 7in 250, it just seemed to me maybe they where to shory but i have yet to put the car on the ground and compress them. what did you use in the rear? i got 8in the rear im not sure about the lbs though. thanks for the info and the car is coming along great!
          • 350lb 7in in back
            Way too many cars
            :woc:
            • The reluctor ring is welded on. It's not pretty but hopefully it won't come off. Would go mount the sensor tonight but roommate says were cleaning house tonight.
              Way too many cars
              :woc:
              • Well plans changed so I went over and welded it up.
                Way too many cars
                :woc:
                • looks like it will work
                  Mike, AKA the sasquatch
                  • I do hope you have the missing tooth indexed correctly...
                    Jim DeAngelis
                    • 9 teeth ahead of the sensor
                      Way too many cars
                      :woc:
                      • Motors back in and its sitting on the ground. First time in over a year.
                        pics of coilover top hats
                        Way too many cars
                        :woc:
                        • Looking Great :thumbright:
                          -93' L BP swap/e-series, coilovers, RIO front swap, redrilled festy drums, Miata 14" 7 spokes.
                          -85' Nissan Sentra 5 spd.
                          • Ya that is looking pretty good
                            Any idea of a timeline when this thing might move under its own power?
                            • looking forward to seeing this festiva done
                              keep up the good work man
                              the heart beat of america stops here______________/\
                              \/\_____________FORD
                              FOREVER
                              • looks good, i like how it sits how much power are you hoping to make this time around?
