Big_ty2003's 1993 L Festy Build Thread
  • #91
    I think I will just add a soft plastic piece on my key chain and use that pry the gas door open. Its a lot less work than rigging something up
    1993 Festiva L, aspire swapped, selling parts for a BP+T build.
    • #92
      True...but you have been so creative so far I ams ure you could rig it up!
      • #93
        It is going to look similar to this, I hope.
        With these wheels
        My open style grille with black mesh & maybe a spoiler
        • #94
          Don't you lose front legroom with those oversize wheels?
          • #95
            they are 15x6.5 with a +35 offset. I am going to run 195/45/15 so I doubt I will have any troubles.
            • #96
              Just put a small magnet on your keychain.That should do it.Get rid of the latch inside.Put a single hinge from another car on the inside that ,when opened ,stays open and when closed ,holds itself closed with a little tension.
              • #97
                My hinge is actually pretty stiff and holds itself shut pretty well.
                Maybe I can get or make a little felt covered magnet pull like you said for my keychain.
                • #98
                  Cut some new gaskets for my smoothie tail lights I am going to install after I finish the paint job. I used some foam rubber I got from work.
                  I have enough material to make about 4 more sets of these if anyone is interested.
                  • #99
                    Those gaskets look good
                    • How's the silver bullet coming along? Haven't seen any updates on the paint work in a while?
                      • I started putting it back together last night. My corner lights & my turns in the front won't work.
                        • not quite put all the way back together yet but here is a pic
                          • Sweet!
                            -85' Nissan Sentra 5 spd.
                            • My Cressida gas cap door latch release quit working on a day when I was impatient. I put a magnet where it could grab the door. It works pretty good.
                              qroger
                              • Car looks good. As for the gas door why not install a cable out of a 323 that has the lever to open the door? It would also unlock the hatch. They fit in a Festiva.
                                93 GL modyfied!!!
                                :fish:
