My KLZE Festiva Build Thread
Could that design cause any vibrations when driving? I know there shouldn't be vibrations, but I could see with a big engine in there almost everything will want to shake around.
Lol thanks, I may touch it up a bit yet before paint but it's mostly done
That's beautiful man..you do pretty nice work. My el cheapo welder would have metal splattered within. A 5' radius lol.. i'd have to regrind the whole engine bay!
So while I have the engine out I want to re make my coolant pipe, I only have 1-1/2" clearance between the frame and belts to work with, so originally I used 1-1/4" pipe to squeeze in there
But I have always felt that it was a restriction on the coolant system since it should be 1-1/2" pipe, so here's what I've done so far
Quick pic of the old setup for those who haven't seen before
I took a piece of 1-3/4" and molded it into the frame
That way I can use 1-1/2" to make my coolant pipe and still keep some clearance with the belts
I literally only had to splice 4 wires from the KL harness to get it to run, once you know what your doing, the wiring part is pretty easy
Slightly off topic but before this whole hair brained turbo business
you had it running NA, what sort of engine management setup did you have going on?
Welded the wideband bung in place and welded the oil return fitting into the oil pan, now I just gotta get a return hose and the oil lines are finished
Once I put the engine back in after the pipes are header wrapped, I'll fire it up on the stock ECU to drive it on the car ramps to finish up the exhaust
And yes I'll take a video of it idling with the turbo
See previous page for the advancedynamix forecast on Chris's project. :pOriginally posted by dueces View Postwell you can kiss that goodbye! With my twincharged probe, I spun drag radials all the way to 90mph AT the track.... Torque steer sucks the big one too, lol
