My KLZE Festiva Build Thread
  • I'm debating on making a complete custom harness to go with the MS, ugh I still gotta finish assembling the circuit board lol
    • Hey Chris what is the part # on the diff or will mine be different then yours?
      the heart beat of america stops here______________/\
      \/\_____________FORD
      FOREVER
      • Mike - yours would be the same as mine, i don't have a part number but here's a link
        You want the Mazda G series 26 spline diff....... i got mine second hand so i didn't have to pay the full price thank god lol
        • Wow that is up there eh lol
          Thanks
          FOREVER
          • So glad you're getting that diff. I don't want to see you going through 7 transmissions....
            1991 Mercury Capri XR2 "GTXR2" BPT Swapped AWD Conversion
            Rocketchips!
            Bolt-on Weber Carb Adapters!
            • ^^lol make that 14, for every diff I destroy if it takes out the casing too then I need two trannies to make one
              • Picked up the oil supply line and fittings today, I went to get the return line supplies but forgot to check the size of the outlet on the turbo to know what size I needed to pick up lol
                • just one of those ddduuuhhhh moments. hows the MS coming along?
                  1991 blue L, 5 speed.
                  1988 red L-plus-all stock.
                  • I actually haven't touched it in a while, I been meaning to get it finished up lol
                    • tisk tisk, get to work!!!! i wanna hear this thing scream!!! what are you lacking as of now? tranny assembly, oil lines,?
                      • My to do list includes
                        -Finish megasquirt
                        -Buy 6 coil-on-plugs and KLG4 crank pulley
                        -connect the turbo downpipe to the rest of the exhaust
                        -install the wideband
                        -install oil lines
                        It's really not a lot left and I have lots of time to do it before spring
                        • excuses excuses
                          • -Wait to the snow to clear up.
                            • We've barely gotten any snow this year, it's the salt that I don't want on it
                              So today I bent and installed the oil pressure line, next I'll be getting supplies for the return line
                              Marked/drilled the hole for the wideband, next I need to weld the bung for it
                              Welded the wastegate actuator back onto the turbo
                              And tore down the engine to get it ready to pull for when my Mfactory diff arrives
                              • now that more like it big guy!!!
