My KLZE Festiva Build Thread
  • Welded the wideband bung in place and welded the oil return fitting into the oil pan, now I just gotta get a return hose and the oil lines are finished
    Once I put the engine back in after the pipes are header wrapped, I'll fire it up on the stock ECU to drive it on the car ramps to finish up the exhaust
    And yes I'll take a video of it idling with the turbo
    • Slightly off topic but before this whole hair brained turbo business you had it running NA, what sort of engine management setup did you have going on?
      "Its not fast, but its fast for a festiva."
      • Originally posted by turbokid View Post
        Just a stock KL ECU, nothing special
        • Originally posted by Damkid View Post
          You make it sound so simple. Haha. I'd never get it running.
          • I literally only had to splice 4 wires from the KL harness to get it to run, once you know what your doing, the wiring part is pretty easy
            • Yeah but it's that first part that gets most!!!
              1991 blue L, 5 speed.
              1988 red L-plus-all stock.
              • Ya but that's what wiring diagrams are for
                • So while I have the engine out I want to re make my coolant pipe, I only have 1-1/2" clearance between the frame and belts to work with, so originally I used 1-1/4" pipe to squeeze in there
                  But I have always felt that it was a restriction on the coolant system since it should be 1-1/2" pipe, so here's what I've done so far
                  Quick pic of the old setup for those who haven't seen before
                  I took a piece of 1-3/4" and molded it into the frame
                  That way I can use 1-1/2" to make my coolant pipe and still keep some clearance with the belts
                  • That's beautiful man..you do pretty nice work. My el cheapo welder would have metal splattered within. A 5' radius lol.. i'd have to regrind the whole engine bay!
                    2008 Kia Rio- new beater
                    1993 Festiva- Fiona, DD
                    1997 Aspire- Babyspire, DD
                    1994 Aspire - Project Kiazord
                    1994 Aspire- Crustyspire, RIP
                    • Lol thanks, I may touch it up a bit yet before paint but it's mostly done
                      • great idea and work!!!
                        • thats a cool idea, nice work.
                          check your pm's when you get a sec.
                          • Could that design cause any vibrations when driving? I know there shouldn't be vibrations, but I could see with a big engine in there almost everything will want to shake around.
                            • KL's are a very very smooth running engine, I have solid mounts and you'd never know it, so no, this won't cause any issues
                              • tonight i almost got my MS finished up, i have a few questions on a few of the steps, but once those questions are answered, i will finish up the last few things
