My KLZE Festiva Build Thread
  • Buy titanium header wrap, it doesn't need to be soaked, is isn't made of fiberglass, and it has a higher heat rating than their other wrap. Oh and make sure you read up on the spray before you install.
    -M3NTAL MARK! Woo!!
    • Thanks for the tips Marcus, I haven't research the header wrap yet but I've research nitrous quite a bit, since I have a wet kit, it shouldn't be bad to get running right..... I don't plan to use the nitrous until I get the turbo dialed in, more or less tune one thing at a time
      • What are u talking about!
        1989 Ford Mustang GT 5.slow
        1996 Ford F-150
        • KlzeTno2! Mind is blown
          1996 Ford F-150
          • There's a Buick guy out there running a fogger nozzle in his exhaust as an afterburner to help his turbo spool Apparently much better than normal antilag
            1991 Mercury Capri XR2 "GTXR2" BPT Swapped AWD Conversion
            Rocketchips!
            Bolt-on Weber Carb Adapters!
            • ^^that would be neat to see, I most likely won't ever do that but it's still neat lol
              Didn't you see my pic earlier in this thread about the nitrous kit I bought? Came with 5 different nozzles ranging from 35-75 shot, at the track I don't plan on using it until 3rd gear when I may have traction lol
              • Go go gadget- rocket pack 
                1991 blue L, 5 speed.
                1988 red L-plus-all stock.
                • You won't need the spray till 4th gear. Lol
                  1996 Ford F-150
                  • Chris at the drags;
                    Yellow one, Chris revs up anticipating and counting seconds,
                    " One one thousand, two one thousand"
                    The turbo starts to pre spool under the hood.
                    Yellow two,
                    " One one thousand, two one"
                    Out goes the hydraulic clutch pedal, turbo spoiled perfectly, a perfect .501 rt
                    First gear, Chris thinks to himself,
                    " Ahhh yes, both tires spinning as they should, nice and even"
                    Second gear,
                    " mmmm, the sweet smell of Mickey Thompson's tasty blend melting beneath my feet"
                    Third gear,
                    " what's this? They are starting to grip? I can't have that!, good thing I programmed in the..."
                    75 shot of n2oh! starts squirting, instantly spinning the tires once again,
                    " Much better! Burn, burn, burn!"
                    Fourth gear,
                    " There is nothing like spinning the tires at 90!"
                    Fifth gear,
                    " but I prefer to ignite them at 110! Hahaha!"
                    The devious laughter ensues while Chris pilots his monster to a 11.90 second 1/4 mile burnout!
                    Well done ye abuser of the rubber! Lol
                    • :laughing3: that's hilarious Charlie, but probably not far off either lol
                      • Can't wait to see it!
                        • It probably spins alot in second n/a doesn't it?
                          • Originally posted by 91mcnasty View Post
                            Depending on how I drive it, if I power shift into second, yes, it lights right up, but if I'm already in second and floor it, it holds traction quite well.... Only exception is at the track, it usually only chirps in second
                            • well you can kiss that goodbye! With my twincharged probe, I spun drag radials all the way to 90mph AT the track.... Torque steer sucks the big one too, lol
                              93 Probe GT-Twincharged-11.992@115mph 10lbs
                              -11.940@111.66mph 14lbs(Slipping clutch)
                              123.7mph highest trap
                              95 Probe GT-RWD-4.8LS-Turbo in process-10.240@135.3mph, Turboed, 3300 race weight
                              • Originally posted by dueces View Post
                                See previous page for the advancedynamix forecast on Chris's project. :p
